Elite 344 USB2 image number 0
Elite 344 USB2 image number 1
Elite 344 USB2 image number 2
Elite 344 USB2 image number 3
Elite 344 USB2 image number 4
Elite 344 USB2 image number 5
Elite 344 USB2 image number 6
Elite 344 USB2 image number 7
Elite 344 USB2
Elite 344 USB2
Elite 344 USB2
Elite 344 USB2
Elite 344 USB2
Elite 344 USB2
Elite 344 USB2
Elite 344 USB2
Elite 344 USB2
Elite 344 USB2
  • Materials Steel
  • Pre-installed Fans - Front 1x 120mm
  • Fan Support - Side 1x 90mm
  • Legacy Cases
  • Materials Plastic
  • Power Supply Support Top mount
  • Size Mini Tower
  • 5.25" Drive Bays 2
  • I/O Panel 2x USB 2.0
  • Fan Support - Rear 1x 90mm
  • Fan Support - Rear 1x 80mm
  • Series Elite Series
  • Materials Polymer
  • Expansion Slots 4
  • Power Supply Support Standard ATX PS2
  • Fan Support - Front 1x 120/90/80mm
  • I/O Panel 1x Mic
  • 3.5" Drive Bays 1 (exposed)
  • Color(s) Black/Blue
  • 3.5" Drive Bays 5 (hidden)
  • Color(s) Black / Silver
  • I/O Panel 1x Audio (Support Intel HD Audio / AC 97)
  • Maximum Compatibility - CPU Cooler Height 148mm / 5.8 inch
  • Color(s) Black / Purple
  • Maximum Compatibility - VGA Card Length 250mm / 9.8 inch (w/ the 2nd HDD cage)
  • Maximum Compatibility - VGA Card Length 363mm / 14.3 inch (w/o the 2nd HDD cage)
  • Dimensions (L x W x H) 183 x 356.8 x 436mm
  • Model Number RC-344-SKN1
  • Model Number RC-344-PKN1
  • Model Number RC-344-BKN1
