Elite 330U
Elite 330U
Color(s)Black
SizeMid Tower
LegacyCases
Cooling System - Side120/140mm fan x 2 (optional)
Cooling System - Bottom1x 80/90/120mm Fan (Optional)
Cooling System - Rear120mm fan x 1 (installed, 1200 RPM, 17 dBA)
I/O Panel2x USB 2.0
Expansion Slots7
SeriesElite Series
Power Supply SupportStandard ATX PS2 (optional)
Cooling System - Rearor 80/90mm fan x 1 (optional)
MaterialsSteel body
Cooling System - Front120/140mm fan (optional)
Weight4.6 kg / 10.1 lbs
I/O Panel1x Mic
Materialsmesh front bezel
MaterialsABS Plastic
5.25" Drive Bays4 (exposed)
3.5" Drive Bays1 (exposed)
I/O Panel1x Audio (supports HD audio)
3.5" Drive Bays5 (hidden)
Dimensions (L x W x H)193 x 427 x 495 mm / 7.6 x 16.8 x 19.5 inch
Model NumberRC-330U
