Elite 311 Plus
Elite 311 Plus
I/O Panel1x USB 3.0
Color(s)Black
SizeMid Tower
LegacyCases
Cooling System - Front120 x 25mm blue LED fan x 1/ 1200RPM / 17dBA
Cooling System - Rear120 x 25mm fan x 1 / 1200 RPM / 17 dBA (installed)
SeriesElite Series
Power Supply SupportStandard ATX PS2 (optional)
Motherboard SupportATX
Expansion Slots7
I/O Panel3x USB 2.0
Motherboard SupportMicro ATX
MaterialsSteel body
Maximum Compatibility - VGA Card Length281mm / 11.1 inch (w/ HDD cage)
Maximum Compatibility - CPU Cooler Height157mm / 6.2 inch
5.25" Drive Bays3 (exposed)
I/O Panel1x Mic
MaterialsABS Plastic
I/O Panel1x Audio (supports HD audio)
Weight5.9 kg / 13 lbs
3.5" Drive Bays2 (exposed)
3.5" Drive Bays5 (hidden)
MaterialsMesh front panel
Maximum Compatibility - VGA Card Length422mm / 16.6 inch (w/o HDD cage)
Color(s)Titanium
Dimensions (L x W x H)190 x 450 x 477 mm / 7.5 x 17.7 x 18.8 inch
Product NumberRC-311P
