Elite 301 Lite Steel Left Panel image number 0
Elite 301 Lite Steel Left Panel image number 1
Elite 301 Lite Steel Left Panel image number 2
Elite 301 Lite Steel Left Panel image number 3
Effortless Efficiency
High in value and attention to detail, Cooler Master’s Elite 301 lite offers users a cost effective, space conscious solution to gaming and computing needs.
Elite 301 features a large intake grill to ensure a smooth, and efficient running system. The fully black coating and included PSU cover allows for clean builds that are visually appealing as well as functional.
Tool-less Intake Panel
Constructed with a substantially large, unrestricted intake grill to ensure that the system runs cool and efficiently. The front panel could be easily removed by magnets, making it easier for daily maintenance.
Versatile Cooling Options
Supports up to six fans and 280mm radiator to ensure that performance is not compromised.
Large Support, Minimized Footprint
Despite its compact size, Elite 301 lite supports up to 365mm graphics cards, 163.5mm CPU Coolers, providing solid potential for future upgrades.
The PSU cover is ventilated on top of the power supply location, allowing actively cooled units to be installed in multiple orientations, while maintaining support for passively cooled power supplies.
  • Model Number E301L-KNNN-S00
  • Materials Steel, Plastic
  • Materials Steel (Left Side Panel)
  • Dimensions (L x W x H) 390 x 203.5 x 430mm incl protrusions / 377 x 203.5 x 410mm excl protrusions
  • Motherboard Support ITX / Micro ATX
  • Volume 34.13L (incl. Protrusions)
  • Expansion Slots 4
  • 3.5" Drive Bays 1
  • 2.5" Drive Bays 1 (Max. 2)
  • I/O Panel 1x USB 3.2 Gen 1 Type-A
  • I/O Panel 1x USB 3.2 Gen 1 Type-C
  • Pre-installed Fan(s) - Front 2x 120mm Black Fan
  • Pre-installed Fans - Rear 1x 120mm Black Fan
  • Clearance - CPU Cooler 163.5mm
  • Clearance - PSU 160mm / 6.29"
  • Clearance - GFX 365mm (without front fans & radiator)
  • Cable Routing 18.5mm
  • Dust Filters Top / Bottom / Front
  • Power Supply Support ATX
