Elite 120 Advanced White image number 0
Elite 120 Advanced White image number 1
Elite 120 Advanced White image number 2
Elite 120 Advanced White image number 3
Elite 120 Advanced White image number 4
Elite 120 Advanced White image number 5
Elite 120 Advanced White image number 6
Elite 120 Advanced White image number 7
Elite 120 Advanced White image number 8
Elite 120 Advanced White image number 9
Elite 120 Advanced White image number 10
  • I/O Panel 1x USB 3.0
  • Materials - Appearance Aluminum
  • Cooling System - HDD cage 120mm fan x 1 (optional)
  • Maximum Compatibility - PSU Length 180mm / 7.1 inch (w/ less cable management)
  • Maximum Compatibility - PSU Length 142mm / 5.6 inch (w/ full cable management)
  • Maximum Compatibility - CPU Cooler Height 65mm / 2.5 inch
  • Legacy Cases
  • 5.25" Drive Bays 1
  • Size Mini ITX
  • Materials - Appearance Polymer front mesh panel
  • Materials - Body Steel alloy
  • I/O Panel 2x USB 2.0
  • Series Elite Series
  • Expansion Slots 2
  • Cooling System - Side 80x15mm fan x 1, 2000 RPM, 20 dBA
  • 3.5" Drive Bays 3 (hidden)
  • Weight 3.3 kg / 7.3 lbs
  • Power Supply Support Standard ATX PS2
  • I/O Panel 1x Mic
  • Maximum Compatibility - VGA Card Length 343mm / 13.5 inch
  • I/O Panel 1x Audio (Support Intel HD Audio / AC 97)
  • 2.5" Drive Bays 4 (hidden; converted from two 3.5" drive bays)
  • Cooling System - Front 120mm fan x 1, 1200 RPM, 19 dBA
  • Color(s) White (w/ interior black coating)
  • Dimensions (L x W x H) 240 x 207 x 401 mm / 9.4 x 8.2 x 15.8 inch
  • Model Number RC-120A-WWN1
