Dyn X Steering Mount Adapter image number 0
Dyn X Steering Mount Adapter image number 1
Dyn X Steering Mount Adapter image number 2
Dyn X Steering Mount Adapter image number 3
Dyn X Steering Mount Adapter image number 4
Dyn X Steering Mount Adapter image number 5
Dyn X Steering Mount Adapter image number 6
Wide Range Of Compatibility
Add support for many more models of front mount wheelbases.
High Durability
Durable as expected from Dyn X professional sim racing cockpit.
  • Product Number IXM-SA1-1
  • Color Black
  • Material Carbon Steel (Thickness: 6 mm)
  • Hole Pattern 130mm diameter / 95mm*65mm
  • Dimensions 166 diameter x 5T
