DEVASTATOR 3 Gaming Combo (2022) image number 0
DEVASTATOR 3 Gaming Combo (2022) image number 1
DEVASTATOR 3 Gaming Combo (2022) image number 2
DEVASTATOR 3 Gaming Combo (2022) image number 3
DEVASTATOR 3 Gaming Combo (2022) image number 4
DEVASTATOR 3 Gaming Combo (2022) image number 5
DEVASTATOR 3 Gaming Combo (2022) image number 6
DEVASTATOR 3 Gaming Combo (2022) image number 7
DEVASTATOR 3 Gaming Combo (2022) image number 8
DEVASTATOR 3 Gaming Combo (2022) image number 9
A Gaming Combo with Color
The Devastator 3 Combo (2022) is the classic of Devastator series.
  • Mouse Sensor Optical
  • Keyboard Material Plastic
  • Keyboard LED Color RGB
  • Keyboard Color Black
  • Keyboard Multimedia Key Dedicated
  • Mouse Connector Cable USB 2.0
  • Keyboard N Key Rollover 26keys Anti-Ghosting
  • Keyboard Connector Cable USB 1.1 (PC)
  • Keyboard Type Membrane
  • Product Keyboard Mouse Combos
  • Mouse Buttons 7
  • Mouse Connector Cable Fixed PVC
  • Mouse Connector Cable 1 .8m
  • Keyboard Connector Cable PVC
  • Keyboard Polling Rate 125Hz / 8ms
  • Mouse LED Color 5-zone RGB
  • Keyboard Connector Cable 1.8M
  • Keyboard Connector Cable USB Type-A
  • Keyboard Switch Type Membrane
  • Compatible OS Windows 7 / 8 / 10
  • Keyboard Keycaps ABS Painting & Laser-engraved
  • Mouse DPI 7 levels (400, 800, 1200(Default), 1600, 3200, 4000, 4800)
  • Keyboard Dimensions (L x W x H) 450 x 148 x 36 mm / 18 x 5.8 x 1.4 inches
  • Keyboard Weight 898g / 2 lbs (without Cable)
  • Mouse Dimensions 119 x 64.6 x 36.7 mm / 4.7 x 2.5 x 1.4 inches (L x W x H)
  • Mouse Weight 128g / 0.3 lb (incl. Cable)
  • Product Number SGB-3000-KKMF3-**
