COSMOS C700P image number 0
COSMOS C700P image number 1
COSMOS C700P image number 2
COSMOS C700P image number 3
COSMOS C700P image number 4
COSMOS C700P image number 5
COSMOS C700P image number 6
COSMOS C700P
COSMOS C700P
COSMOS C700P
COSMOS C700P
COSMOS C700P
COSMOS C700P
COSMOS C700P
RAISING THE BAR(S)
COSMOS C700P
  • Size Full Tower
  • Materials Steel
  • Radiator Support - Bottom 120mm
  • Dimensions (L x W x H) 639 x 306 x 651mm
  • Fan Support - Bottom 2x 120/140mm*
  • Note * Requires additional cooling bracket
  • EAN Code 4719512063712
  • UPC Code 884102036392
  • Pre-installed Fans - Rear 1x 140mm, 1200RPM
  • Radiator Support - Front 420mm (requires removal of ODD cage)
  • Legacy Cases
  • Pre-installed Fans - Front 2x 140mm, 1200RPM
  • Lighting Support RGB Control Board
  • Radiator Support - Bottom 140mm
  • Radiator Support - Rear 140mm
  • Materials Plastic
  • Materials Tempered Glass
  • 2.5" Drive Bays 2
  • 5.25" Drive Bays 1
  • Lighting Support 1x RGB Connection
  • Fan Support - Top 3x 120/140mm
  • Radiator Support - Bottom 240mm*
  • Power Supply Support ATX PS2 / EPS 12V
  • I/O Panel 4x USB 3.0
  • Expansion Slots 8
  • Radiator Support - Top 280mm
  • Series COSMOS Series
  • Materials Aluminum
  • Color(s) Gun Metal / Black
  • Motherboard Support E-ATX
  • Motherboard Support ATX
  • Clearance - GFX 320mm (w/ 3.5" HDD cage)
  • I/O Panel 1x USB 3.1 Gen 2 Type-C
  • Clearance - CPU Cooler 198mm
  • Radiator Support - Top 360mm & 420mm (remove ODD, maximum thickness clearance 70mm)
  • I/O Panel Fan Speed
  • I/O Panel RGB Control Buttons
  • Clearance - GFX 490mm (w/o 3.5" HDD cage)
  • Weight 22.2 kg
  • Model Number MCC-C700P-MG5N-S00
