COSMOS INFINITY 30th Anniversary Edition image number 0
COSMOS INFINITY 30th Anniversary Edition image number 1
COSMOS INFINITY 30th Anniversary Edition image number 2
COSMOS INFINITY 30th Anniversary Edition image number 3
COSMOS INFINITY 30th Anniversary Edition image number 4
Celebrating 30 years of "Making It Yours"
The Cosmos Infinity 30th Anniversary is a remastered limited edition C700M rebuilt with premium materials and a unique Chameleon color scheme
  • Model Number MCC-C700M-KHNN-S30
  • Color(s) Black & copper
  • Materials - Body Steel
  • Materials - Side Panel Curved Tempered Glass, Steel
  • Materials - Outlook Aluminum, Plastic, Steel
  • Dimensions (L x W x H) 650 x 306 x 651mm / 25.6 x 12.0 x 25.6 inch
  • Motherboard Support Mini-ITX, Micro-ATX, ATX, E-ATX (305x272mm/12"x10.7")
  • Expansion Slots 8
  • 3.5" Drive Bays 2
  • 2.5" Drive Bays 3 (Max. 5)
  • I/O Port - USB Ports / USB 3.1 Type-C 1
  • I/O Port - USB Ports / USB 3.0 Type-A 4
  • I/O Port - Audio - 3.5mm Headset Jack (Audio+Mic) 1
  • I/O Port - Audio - 3.5mm Mic Jack 1
  • I/O Port - Fans / Lighting Fan Speed Control Button
  • I/O Port - Fans / Lighting ARGB Control Button
  • Pre-installed Fans - Front 3x 120mm 30th Anniversary MOBIUS ARGB Fan
  • Pre-installed Fans - Rear 1x 120mm 30th Anniversary MOBIUS ARGB Fan
  • Fan Support - Top 3x 120/140mm
  • Radiator Support - Top 120mm, 140mm, 240mm, 280mm, 360mm, 420mm (70mm thickness clearance with conventional layout)
  • Radiator Support - Front 120mm, 140mm, 240mm, 280mm, 360mm, 420mm (64mm thickness clearance with conventional layout)
  • Clearance - CPU Cooler 198mm
  • Clearance - GFX 490mm
  • Accessories 400mm PCI-E 4.0 x16 Riser Cable (Compatible only with PCI Express 4.0 Gen 3 and below)
  • Size Full Tower
  • Series COSMOS Series
