COSMOS II 25th Anniversary Edition image number 0
COSMOS II 25th Anniversary Edition image number 1
COSMOS II 25th Anniversary Edition image number 2
COSMOS II 25th Anniversary Edition image number 3
COSMOS II 25th Anniversary Edition image number 4
COSMOS II 25th Anniversary Edition image number 5
COSMOS II 25th Anniversary Edition image number 6
COSMOS II 25th Anniversary Edition image number 7
COSMOS II 25th Anniversary Edition image number 8
COSMOS II 25th Anniversary Edition image number 9
COSMOS II 25th Anniversary Edition image number 10
COSMOS II 25th Anniversary Edition image number 11
COSMOS II 25th Anniversary Edition image number 12
The Ultra Tower
  • Size Full Tower
  • Motherboard Support SSI EEB
  • Expansion Slots 10+1
  • Materials - Appearance Aluminum
  • Materials - Body Steel
  • Drive Bays - 2.5" SSD 11 (converted from 3.5" cages)
  • Fan Support - HDD 120mm fan x 3 (2 fans for bottom HDD / 1 fan for middle HDD (optional))
  • Liquid Cooling Support - Top 240mm/280mm radiator (max 320mm radiator)
  • Clearance - GFX 190mm-385mm
  • Legacy Cases
  • Fan Support - Rear 1x 140mm Fan Installed (optional: 1x 120mm fan)
  • Materials - Appearance Mesh
  • Color(s) Black
  • I/O Panel 2x USB 3.0
  • Motherboard Support SSI CEB
  • Materials - Appearance Plastic
  • Fan Support - Front 1x 200mm LED Fan Installed (optional 1x 120/140mm fan)
  • Materials - Body Aluminum
  • Materials - Side Panel Glass
  • Dimensions (L x W x H) 664 x 344 x 704 mm / 26.1 x 13.5 x 27.7 inch
  • EAN Code 4719512057445
  • UPC Code 884102031076
  • Series COSMOS Series
  • Motherboard Support XL-ATX
  • 5.25" Drive Bays 3
  • Power Supply Support EPS 12V (Optional)
  • Motherboard Support E-ATX
  • Motherboard Support ATX
  • 3.5" Drive Bays 13 (2 from X-dock with key locks, 5 HDDs in the middle cage, 6 HDDs in the bottom cage)
  • I/O Panel 4x USB 2.0
  • Color(s) Silver
  • Clearance - CPU Cooler 190mm
  • Fan Support - Top 1x 120mm Fan Installed (optional: 1x 200mm / 2x 140mm / 3x 120mm Fan)
  • Model Number RC-1200-KKN2
