Connect Stand image number 0
Connect Stand image number 1
Connect Stand image number 2
Connect Stand image number 3
Connect Stand
Connect Stand
Connect Stand
Connect Stand
Keep Calm and Connect on Connect Stand
Connect Stand
Metal Mesh Plastic Hybrid
SickleFlow 120 Reverse Edition
Detachable Fan
USB Connectivity
The Connect Stand is Cooler Master's new entry to a cooling solution for your devices. Designed for your network devices, the Connect Stand utilizes a metal mesh and plastic hybrid construct for a sturdy platform while maximizing cooling capabilities.
USB Connectivity
With built in USB connectivity cable management for your devices can be kept clean, tidy, and hassle free.
For Multiple Networking Devices
Cool your router, modem, or any devices so you don’t drop connection in the middle of your game or stream.
Detachable Fan
With the SickleFlow 120 Reverse Edition fan, the enhanced blade curves optimize performance for exceptional bottom up air flow.
  • Product Number MNX-SSRK-12NFK-R1
  • Color Black
  • Material Metal Mesh, Plastic, Rubber
  • Dimensions (L x W x H) 295 x 170 x 74 mm / 11.6 x 6.7 x 2.9 inch
  • Fan Speed 1200 RPM ± 10%
  • Fan Airflow 39.7 CFM ± 10%
  • Fan Noise Level 22.3 dBA
  • Power USB 5V DC
  • USB USB 2.0 x 1
  • Current Consumption 0.21A
  • Power Consumption 1.05W
  • Max. Loading Weight 5 kg
  • Cooler Type Notebook Cooler
  • Series Uncategorized
