Coiled Keyboard Cable image number 0
Coiled Keyboard Cable image number 1
Coiled Keyboard Cable image number 2
Coiled Keyboard Cable image number 3
Coiled Keyboard Cable image number 4
Coiled Keyboard Cable image number 5
Coiled Keyboard Cable image number 6
Coiled Keyboard Cable image number 7
Coiled Keyboard Cable image number 8
Coiled Keyboard Cable image number 9
Coiled Keyboard Cable image number 10
Coiled Keyboard Cable image number 11
The Final Touch To Your Setup
The Coiled Cable from Cooler Master adds one final touch of cool to your setup USB-A to USB-C nylon cable allows for universal keyboard connectivity
  • Color Black
  • Connector USB Type-A to USB Type-C
  • Connector 5-Pin Detachable Aviator Connector
  • Warranty 1 year
  • Compatible Model CK721
  • Compatible Model MK721
  • Pacakging Content Coiled Cable
  • Material Metal
  • Compatible Model CK720 Series
  • Compatible Model SK600 Series
  • Compatible Model Most Type C Keyboards
  • Product Others
  • Color Purple
  • Color White
  • Cable Length Coiled Length: 100mm, Total Cable Length (including coils): 1.5m
  • Color Blue-Purple
  • Color Cyan
  • Color Magenta
  • Material Nylon
  • Material PVC
  • Product Number KB-CBZ1 (Shadow Black)
  • Product Number KB-CWZ1 (Snow White)
  • Product Number KB-CLZ1 (Thunderstorm Blue-Purple)
  • Product Number KB-CPZ1 (Dream Purple)
  • Product Number KB-CCZ1 (Pastel Cyan)
  • Product Number KB-CMZ1 (Candy Magenta)
