CMP 501 image number 0
CMP 501 image number 1
CMP 501 image number 2
CMP 501 image number 3
CMP 501 image number 4
CMP 501 image number 5
CMP 501
CMP 501
CMP 501
CMP 501
CMP 501
CMP 501
DURABLE MEET AFFORDABLE, EASY TO BUILD, EASY TO USE
CMP 501
CMP 501
  • Materials Steel
  • I/O Panel 1x USB 3.0
  • Side Window Yes
  • Dust Filters Front
  • Materials Plastic
  • Color(s) Black
  • Legacy Cases
  • Dust Filters Bottom
  • Fan Support - Rear 1x 120mm
  • Clearance - PSU 180mm/7.1"
  • I/O Panel 1x USB 2.0
  • 2.5" Drive Bays 2 (HDD Tray) + 2 (ODD Cage)
  • Cable Routing - Behind Motherboard Tray 24-31mm / 0.94"-1.22"
  • Expansion Slots 7
  • Motherboard Support ATX
  • Power Supply Support New TM 600
  • Series CMP Series
  • Fan Support - Front 2x 120mm
  • 5.25" Drive Bays 1 (Tool-free)
  • Clearance - CPU Cooler 172mm
  • Fan Support - Top 2x 120mm
  • 3.5" Drive Bays 2 (Tool-free) + 1 (ODD Cage)
  • Dimensions (L x W x H) 426 x 499 x 215mm
  • Clearance - GFX 426mm
  • UPC Code 884102038969
  • EAN Code 4719512066447
  • Model Number CMP-501-1NWRT60-AU
