CMP-350 image number 0
CMP-350 image number 1
CMP-350 image number 2
CMP-350 image number 3
CMP-350 image number 4
CMP-350
CMP-350
CMP-350
CMP-350
CMP-350
CMP-350
CMP-350
  • Color(s) Black
  • Size Mid Tower
  • Legacy Cases
  • I/O Panel 2x USB 2.0
  • Expansion Slots 7
  • Motherboard Support ATX
  • Power Supply Support Standard ATX PS2 (optional)
  • Cooling System - Rear 120 x 25mm fan x 1 / 1200 RPM / 17 dBA (installed)
  • Gross Weight 5.4 kg / 11.9 lbs
  • Cooling System - Rear or 80/90mm fan x 1 (optional)
  • Maximum Compatibility - CPU Cooler Height 155mm / 6.1 inch
  • Maximum Compatibility - VGA Card Length 279mm / 10.9 inch
  • Series CMP Series
  • Materials Steel body
  • Cooling System - Front 120 x 25 mm fan x 1 (optional)
  • 3.5" Drive Bays 6 (hidden)
  • Net Weight 4.7 kg / 10.3 lbs
  • I/O Panel 1x Mic
  • Materials ABS plastic front bezel
  • 5.25" Drive Bays 4 (exposed)
  • 3.5" Drive Bays 1 (exposed)
  • I/O Panel IEEE 1394a (optional)
  • Dimensions (L x W x H) 180 x 408 x 454 mm / 7.1 x 16.1 x 17.8 inch
