CM USB Sound Card image number 0
CM USB Sound Card image number 1
CM USB Sound Card image number 2
CM USB Sound Card
CM USB Sound Card
CM USB Sound Card
Instant Audio Upgrade
CM USB Sound Card
The MH752-ACB USB Sound Card enables premium audio in any headset with a 3.5mm connection.
  • Volume Control Up/Down Buttons (Control Box)
  • Virtual 7.1 Surround Sound ON/OFF Button with Indicative LED
  • Compatibility PC
  • Microphone Volume Control Up/Down Buttons
  • Microphone Mute Control Mute Switch
  • Compatibility NB
  • Compatibility Playstation 4
  • Compatibility Playstation 4 Pro
  • Product Audio
  • Cable Length 1.5m USB cable
  • Connector Cable Input: 3.5mm 4-pole Jack
  • Connector Cable Output: USB Type A
  • Weight 29g / 0.063 lbs
  • Weight 16g / 0.035 lbs (without cable)
  • Dimensions (L x W x H) 65 x 29 x 15 mm / 2.55 x 1.14 x 0.59 inches
  • Product Number MH-752-ACB
