CM Force 251
CM Force 251
Color(s)Black
SizeMid Tower
LegacyCases
Maximum Compatibility - VGA Card Length245mm / 9.6 inch
Maximum Compatibility - CPU Cooler Height129mm / 5.1 inch (With the Side Fan)
Cooling System - Rear80/90/120mm fan x 1 (optional)
I/O Panel2x USB 2.0
Cooling System - Side80/90/120mm fan x 2 (optional)
Maximum Compatibility - CPU Cooler Height154mm / 6.0 inch (Without the Side Fan)
Expansion Slots7
Motherboard SupportATX
Power Supply SupportStandard ATX PS2 (optional)
Motherboard SupportMicro ATX
Cooling System - Front120mm fan x 1 (installed)
Net Weight3.9 kg / 8.6 lbs
5.25" Drive Bays2 (exposed)
I/O Panel1x Mic
3.5" Drive Bays8 (1 exposed, 7 hidden)
I/O PanelAudio In & Out (Supports HD Audio)
Dimensions (L x W x H)180 x 416.6 x 429.5 mm / 7.1 x 16.4 x 16.9 inch
Model NumberFOR-251-KKN1
