CM 690 II Plus White (Asia only)
Cooling System - Bottom2x 120mm Fan (Optional)
Cooling System - HDD cage120mm fan x 1 (optional)
SizeMid Tower
MaterialsPlastic
LegacyCases
Cooling System - Rear120mm red LED fan x 1, 1200RPM, 17dBA
Color(s)White
2.5" Drive Bays2 (converted from one 3.5" drive bay)
Power Supply SupportATX PS2
Cooling System - Front140 x 25 mm Blue LED on /off fan x 1 / 1200 RPM / 19 dBA
Expansion Slots7+1
Power Supply SupportEPS 12V (Optional)
I/O Panel2x USB 2.0
Cooling System - Top120mm fan x 1/ 1200RPM /17dBA (supports 120/140mm fan x 2)
MaterialsSteel body
Gross Weight11.19 kg / 24.67 lbs
Maximum Compatibility - VGA Card Length304mm / 11.96 inch
3.5" Drive Bays6 hidden (4 removable)
MaterialsMesh bezel
I/O Panel1x Mic
Maximum Compatibility - CPU Cooler Height177mm / 6.96 inch
I/O Panel1x eSATA
I/O Panel1x Audio (supports HD audio)
5.25" Drive Bays4 (without the use of exposed 3.5” drive bay)
Dimensions (L x W x H)214.5 x 496 x 528.8 mm / 8.4 x 19.5 x 20.8 inch
Net Weight9.19 kg / 20.26 lbs
Model NumberRC-692P
Confirm your Country
It looks like you're in
