CM 690 II Basic (Asia only) image number 0
CM 690 II Basic (Asia only) image number 1
CM 690 II Basic (Asia only) image number 2
CM 690 II Basic (Asia only) image number 3
CM 690 II Basic (Asia only) image number 4
CM 690 II Basic (Asia only) image number 5
  • Cooling System - Bottom 2x 120mm Fan (Optional)
  • Cooling System - HDD cage 120mm fan x 1 (optional)
  • Color(s) Black
  • Size Mid Tower
  • Materials Plastic
  • Cooling System - Right side 120/140 mm fan x 2 (optional)
  • Cooling System - Left side 80 x 15mm fan x 1 (optional)
  • Legacy Cases
  • Cooling System - Rear 120mm red LED fan x 1, 1200RPM, 17dBA
  • Cooling System - Top 120/140mm fan x 2 (optional)
  • Power Supply Support EPS 12V (Optional)
  • I/O Panel 2x USB 2.0
  • Expansion Slots 7+1
  • Cooling System - Front 120 x 25mm blue LED fan x 1/ 1200RPM / 17dBA
  • Materials Steel body
  • 3.5" Drive Bays 6 (hidden)
  • Materials Mesh bezel
  • I/O Panel 1x Mic
  • I/O Panel 1x eSATA
  • 5.25" Drive Bays 4 (exposed, enclosed with two tool-free systems)
  • Net Weight 8 kg / 17.64 lbs
  • Dimensions (L x W x H) 214.5 x 496 x 528.8 mm / 8.4 x 19.5 x 20.8 inch
  • Model Number RC-692B
