CM 690 II Advanced White image number 0
CM 690 II Advanced White image number 1
CM 690 II Advanced White image number 2
CM 690 II Advanced White image number 3
CM 690 II Advanced White image number 4
CM 690 II Advanced White image number 5
CM 690 II Advanced White image number 6
CM 690 II Advanced White image number 7
CM 690 II Advanced White image number 8
CM 690 II Advanced White image number 9
  • Cooling System - Bottom 2x 120mm Fan (Optional)
  • Cooling System - HDD cage 120mm fan x 1 (optional)
  • Cooling System - VGA holder 80 x 15 mm fan x 1 (optional)
  • Legacy Cases
  • Size Mid Tower
  • Materials Plastic
  • Color(s) White
  • Cooling System - Rear 120mm red LED fan x 1, 1200RPM, 17dBA
  • Cooling System - Front 140 x 25 mm Blue LED on /off fan x 1 / 1200 RPM / 19 dBA
  • Power Supply Support EPS 12V (Optional)
  • I/O Panel 2x USB 2.0
  • Expansion Slots 7+1
  • Cooling System - Top 140 x 25mm fanx1/1200RPM/19dBA(supports120/140mm fan x 2)
  • Materials Steel body
  • Gross Weight 11.19 kg / 24.67 lbs
  • 3.5" Drive Bays 6 hidden (4 removable)
  • Materials Mesh bezel
  • I/O Panel 1x Mic
  • I/O Panel 1x eSATA
  • 5.25" Drive Bays 4 (without the use of exposed 3.5” drive bay)
  • Dimensions (L x W x H) 214.5 x 496 x 528.8 mm / 8.4 x 19.5 x 20.8 inch
  • Net Weight 9.19 kg / 20.26 lbs
  • 2.5" Drive Bays 2.5" HDD Bay x 2 Hidden (converted from one 3.5” drive bay)
  • Model Number RC-692A
