CM 690 II Advanced (USB 3) image number 0
CM 690 II Advanced (USB 3) image number 1
CM 690 II Advanced (USB 3) image number 2
CM 690 II Advanced (USB 3) image number 3
CM 690 II Advanced (USB 3) image number 4
CM 690 II Advanced (USB 3) image number 5
  • Cooling System - Bottom 2x 120mm Fan (Optional)
  • Cooling System - HDD cage 120mm fan x 1 (optional)
  • Cooling System - Left side 120/140mm fan x 2 (optional)
  • Cooling System - Right side 80 x 15mm fan x 1 (optional)
  • Legacy Cases
  • Color(s) Black
  • Size Mid Tower
  • Materials Plastic
  • I/O Panel 2x USB 3.0
  • Cooling System - Rear 120mm red LED fan x 1, 1200RPM, 17dBA
  • 2.5" Drive Bays 2 (converted from one 3.5" drive bay)
  • Cooling System - Front 140 x 25 mm Blue LED on /off fan x 1 / 1200 RPM / 19 dBA
  • Power Supply Support EPS 12V (Optional)
  • I/O Panel 2x USB 2.0
  • Expansion Slots 7+1
  • Cooling System - Top 140 x 25mm fanx1/1200RPM/19dBA(supports120/140mm fan x 2)
  • 3.5" Drive Bays 1 Exposed (converted from one 5.25" drive bay)
  • Materials Steel body
  • 3.5" Drive Bays 6 hidden (4 removable)
  • Materials Mesh bezel
  • I/O Panel 1x Mic
  • 5.25" Drive Bays 4 (without the use of exposed 3.5” drive bay)
  • Weight 9.56 kg / 21.08 lbs
  • Dimensions (L x W x H) 214.5 x 496 x 528.8 mm / 8.4 x 19.5 x 20.8 inch
  • Product Name CM 690 II Advanced (USB 3)
  • Model Number RC-692A-KKN5, RC-692A-KWN5
