CM 690 II Advanced (USB 3)
Cooling System - Bottom2x 120mm Fan (Optional)
Cooling System - HDD cage120mm fan x 1 (optional)
Cooling System - Left side120/140mm fan x 2 (optional)
Cooling System - Right side80 x 15mm fan x 1 (optional)
LegacyCases
Color(s)Black
SizeMid Tower
MaterialsPlastic
I/O Panel2x USB 3.0
Cooling System - Rear120mm red LED fan x 1, 1200RPM, 17dBA
2.5" Drive Bays2 (converted from one 3.5" drive bay)
Cooling System - Front140 x 25 mm Blue LED on /off fan x 1 / 1200 RPM / 19 dBA
Power Supply SupportATX PS2
Power Supply SupportEPS 12V (Optional)
I/O Panel2x USB 2.0
Expansion Slots7+1
Cooling System - Top140 x 25mm fanx1/1200RPM/19dBA(supports120/140mm fan x 2)
3.5" Drive Bays1 Exposed (converted from one 5.25" drive bay)
MaterialsSteel body
3.5" Drive Bays6 hidden (4 removable)
MaterialsMesh bezel
I/O Panel1x Mic
I/O Panel1x Audio (supports HD audio)
5.25" Drive Bays4 (without the use of exposed 3.5” drive bay)
Weight9.56 kg / 21.08 lbs
Dimensions (L x W x H)214.5 x 496 x 528.8 mm / 8.4 x 19.5 x 20.8 inch
Product NameCM 690 II Advanced (USB 3)
Model NumberRC-692A-KKN5, RC-692A-KWN5
