CM 690 II Advanced Black & White Edition (USB 3.0 version)
Cooling System - Bottom2x 120mm Fan (Optional)
Color(s)Black
SizeMid Tower
MaterialsPlastic
I/O Panel2x USB 3.0
LegacyCases
Color(s)White
Cooling System - Rear120mm red LED fan x 1, 1200RPM, 17dBA
Cooling System - Front140 x 25 mm Blue LED on /off fan x 1 / 1200 RPM / 19 dBA
2.5" Drive Bays2 (converted from one 3.5" drive bay)
I/O Panel2x USB 2.0
Expansion Slots7+1
Cooling System - Top140 x 25mm fanx1/1200RPM/19dBA(supports120/140mm fan x 2)
Motherboard SupportATX
Motherboard SupportMicro ATX
3.5" Drive Bays1 Exposed (converted from one 5.25" drive bay)
Power Supply SupportPS2
MaterialsSteel body
Motherboard SupportMini ITX
Maximum Compatibility - VGA Card Length304mm / 11.96 inch
3.5" Drive Bays6 hidden (4 removable)
MaterialsMesh bezel
I/O Panel1x Mic
Maximum Compatibility - CPU Cooler Height177mm / 6.96 inch
I/O Panel1x Audio (supports HD audio)
5.25" Drive Bays4 (without the use of exposed 3.5” drive bay)
Weight9.56 kg / 21.08 lbs
Dimensions (L x W x H)214.5 x 496 x 528.8 mm / 8.4 x 19.5 x 20.8 inch
Model NumberRC-692A-KKN5-BW
