Blue LED Silent Fan 140mm
Screws4 pcs
Rubber4 pcs
3 to 4 pin Adapter1 pcs
LED Number4 Blue LED
Fan Rated Voltage12 VDC
Fan Quantity1 PC
Fan Power Connector3-Pin
LegacyCooling
Fan Life Expectancy35,000 Hours
Fan Bearing TypeSleeve Bearing
Fan Power Consumption1.68W
Fan Rated Current0.14A
Fan Dimensions (L x W x H)140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
Fan Noise Level16 dBA
Fan Weight170g
Fan Air Pressure0.82 mmH2O
Fan Speed1000 RPM
Fan Airflow60.9 CFM
Product NumberR4-L4S-10AB-GP
