Blizzard T2 CPU Air Cooler image number 0
Blizzard T2 CPU Air Cooler image number 1
Blizzard T2 CPU Air Cooler image number 2
Thanks to CoolerMaster’s patented Dual-Loop™ heat pipe design, the Blizzard T2 offers superior cooling performance
  • Actuator Mount Material Carbon Steel
  • Heat Pipe Dimensions Ø6mm
  • Cooler Type Air Cooler
  • Connector 3-Pin
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Heatpipes 4
  • Fan Life Expectancy 40,000 Hours (>4 years constant use)
  • Bearing Type Rifle Bearing
  • Fan Dimensions (L x W x H) 92 x 92 x 25 mm / 3.6 x 3.6 x 1 inch
  • CPU Socket LGA1200
  • Series Blizzard
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • Fan Weight 92g / 0.20lb
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • CPU Socket LGA775
  • CPU Socket AM4
  • CPU Socket AM3+
  • Fan Power Consumption 2.16W
  • CPU Socket AM3
  • CPU Socket AM2+
  • Fan Rated Current 0.17A ± 10%
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Heat Sink Weight 248g / 0.55lb
  • Heat Sink Dimensions (L x W x H) 90 x 51 x 140 mm / 3.5 x 2.0 x 5.5 inch
  • Heat Sink Material Heat Pipes
  • Fan Air Pressure 2.21 mmH2O ± 10%
  • Fan Speed 2200 RPM ± 10%
  • Weight 340g / 0.75lb
  • Dimensions (L x W x H) 93 x 80 x 140 mm / 3.7 x 3.1 x 5.5 inch
  • Fan Airflow 43 CFM (@ 2200RPM)
  • Product Number RR-T2-22FP-R1
