Blade Master 120
Blade Master 120
Fan Rated Voltage12 VDC
Screws4 pcs
Rubber4 pcs
LegacyCooling
Fan Power Connector4-Pin (PWM)
Fan Bearing TypeLong Life Sleeve Bearing
Fan Life Expectancy40,000 Hours
Fan Speed600-2000 RPM (PWM) ± 10%
Fan Airflow21.2 - 76.8 CFM
Fan Air Pressure0.40 - 3.90 mmH2O
Fan Noise Level13 - 32 dBA
Fan Power Consumption4.32W (Max)
Fan Rated Current0.36A (Max)
Weight166g
Product NumberR4-BMBS-20PK-R0
