Addressable RGB LED Controller image number 0
Addressable RGB LED Controller image number 1
Addressable RGB LED Controller image number 2
Addressable RGB LED Controller image number 3
Addressable RGB LED Controller image number 4
Addressable RGB LED Controller image number 5
Addressable RGB LED Controller image number 6
Giving You More For Less
The Addressable RGB LED Controller is a compact size Addressable RGB LED controller that allows you to easily customize your ARGB devices...
  • Power Connector x6 = 2x (400+120+120mm)
  • Software Yes
  • Interface Micro USB 2.0
  • LED Connector Addressable RGB 4 Ports, RGB 1 Port
  • Cooler Type RGB Accessories
  • Accessory 1x Fan Signal Wire
  • Accessory 1x Case Restarting Wire
  • Accessory 1x Motherboard Restart Wire
  • Accessory 1x RGB 4-Pin Connector
  • Accessory 1x RGB 4-Pin Motherboard Connector
  • Accessory 1x USB Header Connector
  • Accessory 1x USB Adapter
  • Accessory 1x Addressable RGB 3-Pin Motherboard Connector
  • Accessory 1x Thermal Detection Sensor Wire
  • Accessory 4x Addressable RGB 3 Pin Connector
  • Series RGB Accessories
  • Dimensions (L x W x H) 88 x 53 x 15mm / 3.5 x 2.1 x 0.6"
  • Product Number MFP-ACBN-NNUNN-R1
