Addressable RGB LED Strip image number 0
Addressable RGB LED Strip image number 1
Addressable RGB LED Strip image number 2
Addressable RGB LED Strip image number 3
Addressable RGB LED Strip image number 4
Addressable RGB LED Strip image number 5
Cooler Master’s Addressable RGB LED Strip features our Addressable Gen 2 RGB LED technology allowing you to fully personalize your lighting.
  • LED Quantity 30 pcs
  • Connector 3-Pin ARGB
  • Rated Voltage 5 VDC
  • Color White
  • Cooler Type RGB Accessories
  • Material Rubber
  • Rated Current 0.45A
  • Power Consumption 2.25W
  • Weight 28g / 0.06 lbs
  • Dimensions (L x W x H) 400mm / 15.7 inch
  • Product Number MFX-GSHN-40NNN-R1
