I70C for LGA 1700 image number 0
I70C for LGA 1700 image number 1
I70C for LGA 1700
I70C for LGA 1700
Surpassing the Standard
I70C for LGA 1700
I70C for LGA 1700 is our popular I70C standard cooler designed for Intel LGA 1700 sockets.
Aluminum fins
with copper insert provide efficient heat dissipation
Addressable RGB Lighting
Compatible with Asus AURA Sync, Gigabyte RGB FUSION, MSI Mystic Light Sync, and ASRock RGB LED
  • Product Number RR-I7C7-18PA-R1
  • CPU Socket LGA1700
  • Heat Sink Material Aluminum
  • Dimensions (L x W x H) 120 x 120 x 70 mm / 4.7 x 4.7 x 2.7 inch
  • Fan Speed 650-1800 RPM ± 10%
  • Fan Airflow 37.08 CFM (Max)
  • Fan Air Pressure 1.33 mmH2O (Max)
  • Fan Noise Level 28 dBA (Max)
  • Fan MTTF >40,000 Hours
  • Fan Connector 4-Pin PWM
  • Fan Rated Current 0.12A
  • Fan Safety Current 0.42A
  • Fan Power Consumption 1.44W
  • Cooler Type Standard Cooler
