Standard Cooler i50 image number 0
Standard Cooler i50 image number 1
Standard Cooler i50 image number 2
Standard Cooler i50
Standard Cooler i50
Standard Cooler i50
Strong Airflow Low Noise
Standard Cooler i50
Compatible with Intel LGA 115X sockets.
60mm super thin design perfectly fits All-in One systems or limited form factor cases.
Aluminum fins provide excellent heat dissipation.
92mm diameter fan with long life expectancy, durable materials, strong airflow, and low noise output.
  • Product Number RH-I50-20FK-R1
  • CPU Socket Intel® LGA 1151 / 1150 / 1155 / 1156 socket
  • Material Aluminum
  • Dimensions (L x W x H) 95 x 95 x 60 mm / 3.7 x 3.7 x 2.4 inch
  • Fan Dimensions (L x W x H) 92 x 92 x 25 mm / 3.6 x 3.6 x 1 inch
  • Fan Speed 2000 RPM ± 10%
  • Fan Airflow 34 CFM ± 10%
  • Fan Air Pressure 1.58 mmH2O ± 10%
  • Fan Noise Level 28 dBA (Max)
  • Fan MTTF 280,000 Hours
  • Fan L-10 Life 40,000 Hours
  • Connector 3-Pin
  • Fan Rated Current 0.17A
  • Power Consumption 2.04W
  • Cooler Type Standard Cooler
  • Series INTEL Series
