Hyper 411 Nano image number 0
Hyper 411 Nano image number 1
Hyper 411 Nano image number 2
Hyper 411 Nano
Hyper 411 Nano
Hyper 411 Nano
Compact Cooler, High Performance
Hyper 411 Nano
Direct contact technology
All black aesthetic
AMD and Intel compatibility
Easy fan mount
HYPER 411 NANO
Cooler Master's high-performance series of CPU air coolers, the Hyper series, is back with the Hyper 411 Nano. The Hyper 411 Nano brings a crop of excellent features to round out the already cutting-edge performance of the Hyper series
HYPER 411 NANO
HYPER 411 NANO
4 heat pipes with direct contact ensure more efficient heat transfer from the CPU to the cooler, enhancing cooling performance.
Easy fan mount
Easily mount fan simplifies the installation process. This allows users to attach and detach the fan quickly, making maintenance and upgrades hassle-free
Improved mounting ensures compatibility with the latest AMD and Intel CPU sockets.
All black aesthetic
An all-black aesthetic gives it a sleek and stylish look, making it a great match for any build focused on a minimalist or stealthy design.
  • Product Number RR-H410-25PK-R1
  • Exterior Color Black
  • Dimensions (L x W x H) 102 x 85 x 136 mm / 4.0 x 3.2 x 5.3 inch
  • Fan Dimensions (L x W x H) 92 x 92 x 25.4 mm / 3.6 x 3.6 x 1 inch
  • Fan Quantity 1 PC
  • Fan Speed 650-2500 RPM (PWM) ± 10%
  • Fan Airflow 45.14 CFM
  • Fan Noise Level 30.04 dBA
  • Fan Pressure 3.25 mmH₂O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.14A
  • Fan Safety Current 0.18A
  • Fan Power Consumption 1.68W
  • Cooler Type Air Cooler
  • Series Hyper
  • Heatpipes 4
