Global Headquarters
SIMPLE YET POWERFUL
Ergonomic design
Full Mesh Board
Silent Cooling
LED Strip & Additional USB Hub
5 ergonomic height settings make sure you are always able to choose the right height for your viewing angle.
The use of full mesh board improves its cooling performance greatly.
A blue LED strip helps you find the right keys on your keyboard and 4 additional USB ports give you all the flexibility to connect your devices.
A 140mm fan, designed for silence, keeps you laptop cool and working smoothly.
