N400 image number 0
N400 image number 1
N400 image number 2
N400 image number 3
N400 image number 4
N400
N400
N400
N400
N400
N400
The N400 case has extensive liquid cooling support and cutting edge air cooling performance all wrapped in a subtle aesthetic.
  • Model Number NSE-400-KKN1, NSE-400-KWN1, NSE-400-KKN2, NSE-400-KWN2
  • Color(s) Midnight Black
  • Materials Polymer, Mesh Front Bezel
  • Dimensions (L x W x H) 501.4 x 190 x 426 mm / 19.7 x 7.5 x 16.7 inch
  • Weight 5.6 kg / 12.3 lbs
  • Motherboard Support Micro-ATX, ATX
  • 5.25" Drive Bays 2 (exposed)
  • 3.5" Drive Bays 1 (exposed), 7 (hidden)
  • 2.5" Drive Bays 3 (hidden)
  • I/O Panel - USB Ports 2x USB 3.0 (int.), 2x USB 2.0
  • I/O Panel - Audio In / Out 1x Audio (supports AC97 / HD Audio), 1x Mic
  • Expansion Slots 7
  • Cooling System - Top 120mm fan x 2 (optional)
  • Cooling System - Front 120mm fan x 2 (one white LED XtraFlo fan installed, one optional) - for KKN1/KWN1, with no PWM / LED XtraFlo - for KKN2/KWN2
  • Cooling System - Rear 120mm XtraFlo fan (no PWM / LED) x 1 (installed) *The bundled XtraFlo fans: 3-pin
  • Cooling System - Left side 120/140mm fan x 1 (optional)
  • Cooling System - Right side 120mm fan x 2 (optional)
  • Power Supply Support Standard ATX PS2 (optional)
  • Maximum Compatibility - VGA Card Length 320mm / 12.6 inch (with HDD cage)
  • Maximum Compatibility - CPU Cooler Height 164mm / 6.4 inch
  • Size Mid Tower
  • Series N Series
