NCORE 100 AIR image number 0
NCORE 100 AIR image number 1
NCORE 100 AIR image number 2
NCORE 100 AIR image number 3
NCORE 100 AIR image number 4
NCORE 100 AIR
NCORE 100 AIR
NCORE 100 AIR
NCORE 100 AIR
NCORE 100 AIR
Max Performance, Minimalist Design
NCORE 100 AIR
Latest Gen GPU Compatiblity
Ultra-Small Footprint
Extendable Frame Design
Open and Toolless Frame Design
Thermal Efficient Layout
Available in Black and White
PREMIUM ALUMINUM PANEL
An anodized aluminum shell makes the Ncore 100 Air stand out as a desktop work of art.
ULTRA-SMALL FOOTPRINT
The Ncore 100 Air is super compact, with a footprint about the size of a small booklet.
EXTENDABLE FRAME DESIGN
The Ncore 100 Air has a compact volume of just 14.7L; however, its frame is designed to expand up to 16.4L when needed.
OPEN AND TOOLLESS FRAME DESIGN
Based on Cooler Master’s ‘Make It Yours’ and staying true to our audience, the open frame design make it easy to build or upgrade the PC. Even the cover features tool-less removal for maximum accessibility.
  • Product Number Black: NR100-KNNN-S00, White: NR100-WNNN-S00
  • Exterior Color Black, White
  • Materials - Exterior Steel, Plastic, Aluminum
  • Materials - Side Panel Aluminum
  • Motherboard Support ITX
  • Graphic Card Support Triple Slot 336 mm length and 140 mm height (PCIe slot can be adjusted for 356 mm GPU length)
  • Expansion Slots 2x PCIe Slot Mounting
  • Drive Bays - 2.5" SSD 1
  • I/O Panel - USB Ports 2x USB 3.2 Gen 1 Type-A, 1x USB 3.2 Gen 2x2 Type-C
  • I/O Panel 1x Audio Combo (Audio In / Out 3.5mm)
  • Clearances - CPU Cooler 50 / 70mm
  • Clearances - Power Supply 100mm
  • Clearances - RAM 50 / 70mm
  • Clearances - Graphics Card 50mm CPU Cooler: 337 x 62 x 180mm / 357 x 79 x 180mm (expansion) (max. space incl. GPU power connector), 70 mm CPU Cooler: 337 x 42 x 180mm / 357 x 59 x 180mm (expansion) (max. space incl. GPU power connector)
  • Pre-installed Fan(s) - Top 120mm CS120 PWM Fan (max. 1200 RPM)
  • Pre-installed Fan(s) - Rear 120mm CS120 PWM Fan (max. 1200 RPM)
  • Dust Filters Side panels
  • Cable Routing - Behind MB Tray 11mm
  • Power Supply Support SFX
  • Included Accessories 1x 240 PCIe 4.0 x 16 Riser Cable, 1x ATX 3.0 power cable for vertical mount
  • Volume 14.7L / 16.4L (incl. protrusions)
  • Dimensions (L x W x H) 155 x 212 x 449mm / 172 x 212 x 449mm (Incl. Protrusions), 155 x 212 x 425mm / 172 x 212 x 425mm (Excl. Protrusions)
  • Size Mini ITX
