MasterLiquid ML360 SUB-ZERO EVO image number 0
New Compact DIY Pump
Redesigned TEC Unit
Ambient Sealing Fence
Addressable Gen 2 RGB
New Mobius 120 ARGB Fans
Intel® Cryo Cooling Technology
Powered by Intel® Cryo Cooling Technology with integrated software to allow customizable overclocking catered to your specific needs.
Thermoelectric Cooling (TEC)
The redesigned TEC unit within the water block accelerates cooling to deliver maximum overclocking of your Intel® processor.
Low Profile Radiator
Low profile radiator with superior fin density coupled with performance fans dissipates heat rapidly.
NEW DIY PUMP
Compact DIY pump upgraded with silent IC delivers better noise performance with small footprint.
  • Product Number MLZ-D36M-A24PZ-17
  • Exterior Color Black
  • CPU Socket LGA1700
  • Radiator Material Aluminum
  • Radiator Dimensions 394 x 119.6 x 27.2 mm / 15.5 x 4.7 x 1.1 inch
  • Pump Dimensions 57.3 x 57.3 x 92.2 mm / 2.3 x 2.3 x 3.6 inch
  • Pump MTTF >198,000 Hours
  • Pump Noise Level 35 dBA
  • Pump Connector 4-Pin
  • Pump Rated Voltage 12 VDC
  • Pump Rated Current 1.0 A
  • Pump Power Consumption 13.8W (Max)
  • Fan Quantity 3 PCS
  • Fan LED Type Addressable Gen 2 RGB
  • Fan Speed 0-2400 RPM ± 10%
  • Fan Airflow 75.2 CFM (Max)
  • Fan MTTF >200,000 Hours
  • Fan Safety Current 0.35A
  • Fan Rated Current 0.18A
  • Fan Power Consumption 2.16W
  • RAM Clearance N/A
  • Warranty 5 years
  • Cooler Type Liquid Cooler
  • Series MasterLiquid
  • Radiator Size 360
