MasterLiquid 360 Core II image number 0
MasterLiquid 360 Core II image number 1
Innovative design
Dual chamber pump
Optimum tubing length
Revamped fans
Updated CPU compatibility
Easy installation
Included Cryo-Fuze thermal paste
MASTERLIQUID 360 CORE II
Building upon the success of the MasterLiquid series, Cooler Master presents the newly redesigned MasterLiquid 360 Core II. Features such as a refined G9R dual chamber pump for silent performance and updated CPU compatibility for total build flexibility make the Core II a next level liquid cooler. With an infinity mirror design on the pump cover, overhauled and enhanced fans, and optimized tubes for easy installation, the Core II is the epitome of powerfully elegant design. Take the cooling power of your setup into the modern era with the MasterLiquid 360 Core II
Innovative Design
An infinity mirror pump cover gives the pump a stellar aesthetics
Dual Chamber Pump
Upgraded design resulting in a compact cooler with superior performance
Optimum Tubing Length
400 mm long tubing enables effortless mounting of the cooler in any orientation
Revamped fans
The brand-new fan blades and revamped aesthetics deliver outstanding performance and a fresh look
UPDATED CPU COMPATIBILITY
The Core II is compatible with all of the latest AMD and Intel CPUs
SUPPORT LGA 1851 RL-ILM SOCKET DESIGN
INCLUDED CRYOFUZE THERMAL PASTE
TUBE CLIPS INCLUDED
  • Product Number MLW-D36M-A18PA-R1
  • Exterior Color Black
  • Radiator Material Aluminum
  • Radiator Dimensions 394 x 119.2 x 27.2 mm / 15.5 x 4.7 x 1.1 inch
  • Tube Length 400 mm / 15.75 inch
  • Pump Dimensions 83 x 76.2 x 52.3 mm / 3.3 x 3 x 2.1 inch
  • Pump Profiles Addressable RGB
  • Pump Speed 3000 ± 300 RPM
  • Pump MTTF >50,000 Hours
  • Pump Rated Voltage 12 VDC
  • Pump Power Consumption 3.6 W
  • Fan Quantity 3 PCS
  • Fan Speed 650-1750 RPM ± 10%
  • Fan Airflow 70.5 CFM (Max)
  • Fan Air Pressure 2.0 mmH2O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Bearing Type Sleeve Bearing
  • Fan Rated Current 0.23 A
  • Fan Safety Current 0.45 A
  • Fan Power Consumption 2.76 W
  • Warranty 5 years
  • Cooler Type Liquid Cooler
  • Radiator Size 360
  • Series MasterLiquid Lite
