Mobius 120 image number 0
Mobius 120 image number 1
Mobius 120
Mobius 120
More Balance, More Burst
Mobius 120
Cooler Master is introducing the Mobius Series representing the performance line of fans with a new entry – Mobius 120.
 PERFECTING ENGINEERING
Cooler Master’s Mobius 120 is our new series of performance fans. With our enhanced Ring Blade Design, the Mobius Series optimizes both performance and acoustics, catering to a dynamic range of applications from case, liquid or air, to overclocking and intense gaming.
OIL REFLOW
DUST PROOFING
ANTI-SWAY SYSTEM
Pressure Acceleration Air Vents
Angled inner frame rim with chamfered side vents boost airflow draw, The structural ring blade eliminates any fan deformation- Ring Blade keeps the fan build structure rigid, inflexible, stiff and rigor
45 deg Q in and Q out, larger air flow in and air flow out increasing the Q
  • Product Number MFZ-M2NN-21NPK-R1
  • Exterior Color Black
  • Fan Profiles Non-LED
  • Fan Speed 0-2050 RPM ± 10%
  • Fan Airflow 63.1 CFM
  • Fan Noise Level 22.6 dBA
  • Fan Air Pressure 2.69 mmH2O
  • Fan MTTF >200,000 Hours
  • Fan Rated Current 0.12A
  • Fan Safety Current 0.35A
  • Fan Power Consumption 1.44W
  • Fan Weight 179g / 0.38 lbs
  • Warranty 5 years
  • Cooler Type Case Fan
  • Series Mobius Series
  • LED Lighting Non-LED
