SickleFlow Edge 120 ARGB 3-Pack Fan Kit image number 0
Same Legend, More Edge
  • Enhanced Fan Blade
  • Redesigned Fan Frame
  • Improved bearing system
  • A1 Mini LED Controller
Enhanced Fan Blade
An improved fan blade provides higher fan speed, air pressure, and airflow while sticking to the same low noise level the SickleFlow is known for.
REDESIGNED FAN FRAME
The SickleFlow’s signature lines are now included in the frame design to provide a more cohesive product design.
IMPROVED BEARING SYSTEM
An enhanced loop dynamic bearing system keeps things running silently smooth.
A1 MINI LED CONTROLLER
Control and customize your SickleFlow Edge 120 Fan Kit's lighting with a compact, easy-to-use mini controller.
  • Product Number MFX-B2DN-253P2-R2
  • Exterior Color Black
  • Fan Airflow 70.7 CFM
  • Fan Noise Level 32.8 dBA
  • Fan Pressure 3.61 mmH₂O
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.2A
  • Fan Safety Current 0.3A
  • Fan Power Consumption 2.4W
  • RGB Connector 3-Pin ARGB
  • RGB Rated Voltage 5 VDC
  • RGB Rated Current 0.21A
  • Fan Weight 168g / 0.37 lbs
