SickleFlow 120 RGB image number 0
SickleFlow 120 RGB image number 1
SickleFlow 120 RGB image number 2
SickleFlow 120 RGB
SickleFlow 120 RGB
SickleFlow 120 RGB
SickleFlow 120 RGB
New Blade Design
Enhanced Fan Frame
Sealed Bearing Structure
Updated Lighting Design
Certified Compatible
SickleFlow 120 RGB, a new series of the CoolerMaster Fan family, provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans. Optimized blade design with updated curve that improves air flow and air pressure. Enhanced frame structure, reducing turbulent flow and noise and increasing overall work efficiency. Sealed and secured fan bearing, preventing dust and lubricating oil leakage while increasing the fan’s operation stability and life span.
Enhanced Fan Frame
  • Product Number MFX-B2DN-18NPC-R1
  • Fan Profiles RGB
  • Fan Speed 650-1800 RPM ± 10%
  • Fan Airflow 62 CFM ± 10%
  • Fan Air Pressure 2.5 mmH2O ± 10%
  • Fan Noise Level 8 - 27 dBA
  • Fan MTTF 160,000 Hours
  • RGB Connector 4-Pin RGB
  • RGB Rated Voltage 12 VDC
  • RGB Rated Current 0.09A
  • Fan Rated Current 0.15A
  • Fan Safety Current 0.37A
  • Fan Power Consumption 1.8W
  • Fan Weight 156g / 0.34 lbs
  • Cooler Type Case Fan
  • Series SickleFlow
  • LED Lighting RGB
  • Fan Size 120
