MasterBox NR400 with ODD image number 0
MasterBox NR400 with ODD image number 1
MasterBox NR400 with ODD image number 2
MasterBox NR400 with ODD image number 3
MasterBox NR400 with ODD image number 4
MasterBox NR400 with ODD image number 5
MasterBox NR400 with ODD image number 6
MasterBox NR400 with ODD image number 7
MasterBox NR400 with ODD image number 8
FORM & FUNCTION STREAMLINED
Minimalistic Design
Seamless Tempered Glass
Ample Storage Support
Versatile HDD Cage
Headset Jack
Fan Support
Radiator Support
Component Clearances
  • Model Number MCB-NR400-KG5N-S00
  • Exterior Color Black
  • Materials - Body Steel, Plastic
  • Dimensions (L x W x H) 411 (L) x 210 (W) x 411 (H) mm
  • Expansion Slots 4
  • 5.25" Drive Bays 1
  • 3.5" Drive Bays 4
  • 2.5" Drive Bays 4
  • Pre-installed Fans - Front 1x 120mm
  • Fan Support - Top 1x 120/140mm
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Front 120 / 140 / 240 / 280mm (may interfere with HDD mounted below ODD)
  • Clearance - CPU Cooler 166mm
  • Clearance - PSU 325mm max (w/o front radiator & HDD cage), 140mm (HDD cage in backmost position)
  • Clearance - GFX 346mm
  • Cable Routing - Behind Motherboard Tray 22mm
  • Dust Filters Top, Bottom
  • Size Mini Tower
  • Series MasterBox Series
