Global Headquarters
GPU Brace with RGB Lighting
Protect the GPU
Universal GPU support
Protect the motherboard
Co-designed with Tantric Mods
RGB ready
Protect your graphics card from bending or sagging over time. Reduce stress or even damage on your motherboard from the weight of the graphics card. ELV8 locks onto expansion slot of any case to give your graphics card added weight support by lifting it from underneath.
