KAZE image number 0
KAZE image number 1
KAZE image number 2
KAZE image number 3
KAZE
KAZE
KAZE
KAZE
M.2 SSD Heatsink
KAZE
Ultra-thin Vapor Chamber
Dual Vapor Chamber
Unique Wick Design
Maximized Heatsink Area
No More Space Limitation
Kaze is Cooler Master's brand new high-performance M.2 SSD heatsink, offering a passive cooling solution to maintain stability and sustained high-speed performance over extended periods. Kaze comes with a dual ultra-thin Vapor Chamber, striking the perfect balance between minimal thickness and optimal thermal conductivity. This innovative design efficiently directs heat away from the newest high-performance double-sided chip M.2 SSDs, ensuring rapid heat dissipation across the heatsink on both sides, enhancing user experience and SSD performance.
Dual Vapor Chamber
Unique Wick Design
  • Product Number MAP-DVCE-N00NN-R1
  • Heatsink Material Aluminum
  • Thermal Pad Thickness 0.5 / 0.02 (mm / inch)
  • ARGB No
  • Compatibility M.2 2280, single-sided and double-sided
  • Included Accessories Screwdriver
  • Weight 38 / 1.34 (g / oz)
  • Dimension 24.3 x 74.0 x 18.0 mm / 0.96 x 2.91 x 0.71 inch (with cover)
  • Dimension 24.3 x 74.0 x 11.2 mm / 0.96 x 2.91 x 0.44 inch (without cover)
  • Note We recommend ensuring proper airflow during high-load operations to optimize the cooling performance of the KAZE SSD on your PS5. For regular use, please follow the official guidelines and keep the protective cover closed.
