Elite 502 image number 0
Elite 502 image number 1
Elite 502 image number 2
Elite 502 image number 3
Elite 502 image number 4
Elite 502
Elite 502
Elite 502
Elite 502
Elite 502
Effortless Efficiency
Elite 502
The Elite 502 delivers exceptional cooling and performance with its advanced mesh front panel for enhanced airflow. Designed for mid-to-entry-level builders, it supports up to a 420mm radiator, 410mm GPUs, and modern back-connector motherboards, offering a streamlined and efficient building experience at an accessible price.
Back-Connected Motherboard Support​
Supports back-connected motherboard design, freeing up space at the front of the case and providing 33-35mm of space behind the motherboard tray for easier cable management.
Optimized Airflow​
Equipped with three 120mm ARGB fans, it offers stable cooling performance while adding stunning lighting effects to your build.
USB Type-C Upgrade​
USB Type C port built into the I/O panel allows multi-purpose, streamlined data transmission. ​
Room For Updates​
Supports a 410mm GPU, a 170mm CPU cooler, and ample space for future hardware upgrades.
Versatile Thermal Options
Supports up to seven 120mm fans and either a top-mounted 360mm radiator or a front-mounted 420mm radiator, offering hyper-effective CPU thermal performance.
Removable HDD Cage
The HDD cage is completely removable, providing better access during assembly and system upgrades.
  • Product Name ELITE 502
  • Product Name ELITE 502 White
  • Model Number ELITE 502: E502-KGNN-S00
  • Model Number ELITE 502 White: E502-WGNN-S00
  • Color(s) ELITE 502: Black / ELITE 502 White: White
  • Materials - Exterior Steel
  • Materials - Right Side Panel Steel
  • Materials - Left Side Panel TG
  • Dimensions (L x W x H) 474 x 230 x 481 mm (Incl. Protrusions), 435 x 230 x 465 mm (Excl. Protrusions)
  • Volume (incl. Protrusions) 49.73 L
  • Motherboard Support ITX / Micro ATX / ATX (Supporting Back-connector Motherboard) / E-ATX (*up to 12"x10.9"/ 30.5cmx27.7cm motherboards, may impact cable management)
  • Expansion Slots 7
  • 5.25" Drive Bays N/A
  • 3.5" Drive Bays 2
  • 2.5" Drive Bays 2 (Max.6)
  • I/O Panel - USB Ports 1x USB 3.2 Gen1 Type A, 1x USB 3.2 Gen1 Type C​
  • I/O Panel - Audio In / Out 3.5 mm Combo x 1
  • Fan Support - Front (Filtered) 140 mm x 3 / 120 mm x 3
  • Fan Support - Top (Filtered) 140 mm x 2 / 120 mm x 3
  • Fan Support - Rear 1x 120mm
  • Pre-installed Fans - Front 3x 120mm ARGB Fans
  • Radiator Support - Front 120 / 140 / 240 / 280 / 360 / 420 mm (Limit: 457*140*27 mm)
  • Radiator Support - Top 120 / 140 / 240 / 280 / 360mm
  • Clearance - CPU Cooler 170mm
  • Clearance - PSU 170 / 210mm (w/o HDD Cage)
  • Clearance - Graphics Card (installed 3.5"HDD BRK) 360 / 410 mm (w/o front radiator)
  • Cable Routing - Behind Motherboard Tray 33-35 mm
  • Dust Filters Top, Front, Bottom
  • Power Supply Support ATX
  • Series Elite Series
  • Size Mid Tower
