Thanks to MiniLED technology, local dimming zones are even smaller and more granular than ever before. With local dimming activated you can obtain extraordinary HDR performance with a contrast ratio of 50,000:1.
Visuals beyond limits
Experience truly immersive HDR performance like never before with the brand-new Tempest GP27Q MiniLED Monitor with 576 local dimming zones. Paired with a Quantum Dot WQHD resolution panel with an extremely fast 165Hz refresh rate, the GP27Q is the perfect next-level upgrade for your setup.
With specifications perfect for both the working professional as well as the hardcore gamer, the Tempest GP27Q is a true do-it-all monitor. Equipped with a 2560 x 1440 resolution panel that covers 98% of the DCI-P3 color spectrum, and boasts 165Hz refresh rate with a 1 ms response time, this monitor can be the perfect centerpiece to your work and play setup.
With a wide range of adjustability, the Tempest GP27Q can be positioned to the way you want it exactly.
2 x USB Type A
1 x Type B
2 x HDMI 2.0
1 x DisplayPort
1 x USB Type C (supports 90W PD charging output)
1 x 3.5mm Headphone Jack
