GM34-CWQ2 image number 0
GM34-CWQ2 image number 1
GM34-CWQ2 image number 2
GM34-CWQ2 image number 3
GM34-CWQ2 image number 4
GM34-CWQ2 image number 5
GM34-CWQ2 image number 6
GM34-CWQ2 image number 7
GM34-CWQ2 image number 8
GM34-CWQ2
GM34-CWQ2
GM34-CWQ2
GM34-CWQ2
GM34-CWQ2
GM34-CWQ2
GM34-CWQ2
GM34-CWQ2
GM34-CWQ2
Dive Into The Gaming World
GM34-CWQ2
The GM34-CWQ2 is designed for everyone and offers outstanding value and competency with UWQHD resolution that empowers your work/play experience
Resolution
GREATER IMMERSION
UWQHD resolution (GM34) offers extra screen-real estate for
increased multi-tasking efficiency and much more immersive content
and gaming. Feature 1500R Curvature which is also the sweet spot for
immersion. Having a more pronounced curvature can start to increase
distortion at certain points of the screen and generally harmful to
content creation applications. With the 1500R curvature, games and
entertainment content are even more immersive, spreading around
you and making you feel more part of the action.
Fluid Visuals
ULTRA- SMOOTH REALISM
FreeSync Premium ensures smooth, lifelike gameplay that accurately reproduces a level of realism to everything you play. By synchronizing the frames outputted from the GPU to the refresh rate of the monitor, you can experience tear-free gameplay that is smoother than ever.
Screen
Fluid
gaming experience
Colors
95% DCI-P3 AND 6-AXIS COLOR ADJUSTMENT
Incredible color detail wide color gamut, GM34-CWQ2 comes equipped with Quantum Dot displays that cover 95% of DCI-P3 respectively making these monitors great for color-sensitive work.
EASY ON THE EYES
Protect your eyes from potentially harmful blue light and ensure prolonged comfort with Low Blue Light and Flicker-Free technologies, minimizing eye strain for extended work or gaming.
Ports & Slots
Connectivity Options
Vivid Colors
4000:1 Contrast & HDR400
Revolutionize your visual experience.
GM34-CWQ2 is equipped with VA panels
which have the benefit of much darker
and deeper blacks, leading to an enhanced
4000:1 contrast ratio. Standard IPS monitors
have a contrast ratio of 1000:1 on average.
Picture in picture (PIP) &  Picture by picture (PBP)
Multitasking
Enhance your productivity, work, chat and play with PBP technology. Seamlessly switch between dual sources at their native resolutions to analyze two projects or run two programs concurrently. Leverage PIP functionality to receive a secondary source, enabling efficient multitasking with ease.
Built-in Dual Speakers
Audio
Experience sound entertainment with 2 built-in speakers no need for extra peripherals. Save desk space and streamline your setup for efficient work, learning, and play.
  • Product Number CMI-GM34-CWQ2
  • Screen Type Curved Series
  • Curve 1500R
  • Ratio 21:9
  • Screen Size 34"
  • Panel VA 10bit (8bit+FRC) w/ Quantum Dot
  • Resolution UWQHD 3440x1440
  • Refresh Rate 165 Hz (Overclock to 180 Hz)
  • Contrast Ratio 4000:1
  • Brightness 320 nits
  • DisplayHDR400 Compatible
  • Color Gamut DCI-P3 95%
  • I/O - DP 1.4 1
  • I/O - HDMI 2.0 2
  • I/O - USB Type C 1 (PD 65W + DP ALT)
  • I/O - USB 3.0 Type B 1
  • I/O - USB 3.0 Type A 2
  • I/O - Earphone Out 1
  • I/O - Speaker 2 (5W)
  • Overdrive Technology Yes
  • VRR Technology FreeSync Premium, FreeSync Range: Yes, G-Sync Range: Yes
  • Response Time 0.5ms (MPRT), 2ms (GtG)
  • Anti-flicker Yes
  • KVM Yes
  • PIP/PBP (Screen Split) Yes
  • Power Consumption 158W (Max)*
  • VESA 100x100 mm
  • Height Adjustment 0-80 mm
  • Swivel Adjustment -15°~+15°
  • Tilt Adjustment -5°~+15°
  • Product Gaming Monitor
  • Monitor Series GM Series
  • Note * Measure a screen brightness of 200nits without audio/USB/Card reader connection.
  • Panel Type VA
