GM27QPA image number 0
GM27QPA image number 1
GM27QPA image number 2
GM27QPA image number 3
GM27QPA image number 4
GM27QPA image number 5
GM27QPA
GM27QPA
GM27QPA
GM27QPA
GM27QPA
GM27QPA
Maximize Every Moment of Work and Play
GM27QPA
Introducing the GM27QPA, Cooler Master’s latest flat-screen monitor designed to accompany you through your daily tasks, whether it be business or fun. The GM27QPA has been designed with a focus on crisp display tech, fluid response time, and color vibrancy, as well as comfort for users looking to pull long sessions. No matter your need, the GM27QPA has got your back all day every day.
A Screen Fit For All Kind of Needs
At 27 inches with IPS panel, the GM27QPA has ample room for users of all kinds. Whether you are a hardcore gamer, avid movie watcher, detail-oriented graphic designer, or multi-tasking office worker, the GM27QPA has the space you need.
Crisp Display
With QHD resolution, you’ll see details previously unseen. Moving your eyes from the world around you to the screen, you’ll hardly notice a difference. Whether you are an FPS gamer looking to really enter into other worlds or a graphic designer trying to maximize your productivity, the GM27QPA will show you details you didn't even know existed.
Crisp Display
Crisp Display
Experience Better Gaming Sessions
The Adaptive Sync feature ensures smooth visuals, even when the frame rate fluctuates.
Built-In Dual Speakers
Experience sound entertainment with 2 built-in speakers- no need for extra peripherals. Save desk space and streamline your setup for efficient work, learning, and play.
Comfort Day and Night
A Low Blue Light Display mode and Flicker Free function ensure the GM27QPA remains easy on the eyes, even during extra long sessions.
Multiple Connections
Connect your devices with I/O ports consisting of:
• HDMI 2.0 x2
• DisplayPort 1.4 x1
• Audio Out
• Power
  • Product Number CMI-GM27QPA
  • Screen Type Flat Series
  • Screen Size 27"
  • Ratio 16:9
  • Resolution 2K QHD 2560x1440
  • Refresh Rate 240 Hz
  • Contrast Ratio 1000:1
  • Brightness 350 nits (Typical)
  • HDR 400
  • HDR Peak Brightness 400 nits
  • Dimming Zones N/A
  • Color Gamut DCI-P3 93% (Typ., CIE 1976), sRGB 97% (Typ., CIE 1931)
  • I/O - DP 1.4 1
  • I/O - HDMI 2.0 2
  • I/O - 3.5mm Audio Out 1
  • Overdrive Technology Yes
  • Response Time 1ms (MPRT), 5ms (GtG)
  • Eye Protection Low Blue Light (S/W)
  • Anti-flicker Yes
  • I/O - Speaker 2 (3W)
  • KVM N/A
  • PIP/PBP (Screen Split) Yes
  • Lighting N/A
  • Power Consumption 46W (Max)
  • VESA 75x75 mm
  • Tilt Adjustment -5°~+20°
  • Swivel Adjustment ±15°
  • Height Adjustment 110mm
  • Pivot Adjustment 0-90°
  • Cooler Master Enhanced Cooling Design N/A
  • Product Gaming Monitor
  • Monitor Series GM Series
  • Panel Type IPS
