Global Headquarters
The Solid, Sturdy, No-Nonsense Work and Play Desk
The GD160 is a simple, do-it-all desk that seamlessly integrates right into your setup. Built with durability and ergonomics in mind, the GD160 offers plenty of workspace and comes with an integrated full-surface mousepad that is water-resistant and easy to clean. It's the perfect companion for your work and play sessions.
With ample space for multi-monitor setups, keyboards, mice and more, the GD160 is made to handle both work and play sessions. Whether you're conquering foes on the battlefield, or scrubbing timelines in Adobe Premiere, it's the perfect desk to tackle whatever you throw at it.
The rear steel tray on GD160 is designed to help keep your cables and adapters neatly organized and out of sight, contributing to a clutter-free workspace. With this effective cable management solution, you can enjoy a more streamlined and efficient setup, making cable organization and accessibility easier than ever before.
The GD160 is thoroughly tested for durability, being able to withstand up to 100kg without breaking a sweat. Rest easy with this battle-tested table as your sturdy companion.
The GD160 comes equipped with a full-surface mousepad that spans across the entire desk. It's made of water-resistant* materials, so fluids don't easily absorb into the mat, making it easier to clean and prolong its lifespan.
*water resistance is only for cold liquids, hot liquids may still absorb into the mat.
