GA2701 image number 0
GA2701 image number 1
GA2701 image number 2
GA2701 image number 3
GA2701 image number 4
GA2701 image number 5
GA2701
GA2701
GA2701
GA2701
GA2701
GA2701
Dive Into The Gaming World
GA2701
GA2701 is a 27-inch FHD monitor with 100Hz refresh rate and Adaptive Sync support. With all the necessary features and specifications, the GA2701 is a value-oriented monitor that provides exceptional performance in both gaming and work applications.
ADAPTIVE SYNC
ADAPTIVE SYNC
GA2701 comes with Adaptive Sync support, providing an extra smooth, tear free experience in your games, Gain a competitive edge over your opponents with less motion smearing and clearer visuals in the games you play.
LOW BLUE LIGHT AND FLICKER FREE
GA2701 is flicker free and has a low blue light mode to further protect your eyes from potentially harmful blue light emissions.
MINIMALISTIC AESTHETIC
GA2701 sticks to the basics a with a no-nonsense design focusing on a minimalistic aesthetic. The clean design is sure to seamlessly fit into your work and play setup.
 CONNECTIVITY OPTIONS
Connect your devices with the I/O ports consisting of:
• 1 x HDMI
• 1 x VGA
• 1 x 3.5mm Headphone Jack
  • Product Number CMI-GA2701
  • Screen Type Flat Series
  • Ratio 16:9
  • Screen Size 27"
  • Panel IPS 16.7M
  • Quantum Dot No
  • Resolution FHD 1920x1080
  • Refresh Rate 100 Hz
  • Contrast Ratio 1000:1
  • Brightness 250 nits (Typical)
  • HDR N/A
  • Color Gamut sRGB 95%
  • I/O - VGA 1
  • I/O - HDMI 1
  • I/O - Earphone Out 1
  • Response Time 1ms (MPRT)
  • Anti-flicker Yes
  • Overdrive Technology Yes
  • Power Consumption 21.5W
  • VESA 100x100 mm
  • Tilt Adjustment -5°~+20°
  • Product Gaming Monitor
  • Monitor Series GA Series
  • Panel Type IPS
