CH331 USB Gaming Headset image number 0
CH331 USB Gaming Headset image number 1
CH331 USB Gaming Headset image number 2
CH331 USB Gaming Headset image number 3
CH331 USB Gaming Headset image number 4
CH331 USB Gaming Headset image number 5
CH331 USB Gaming Headset image number 6
CH331 USB Gaming Headset image number 7
CH331 USB Gaming Headset image number 8
CH331 USB Gaming Headset image number 9
Essential Audio, Always On
The CH331 USB Gaming Headset enhances the essential audio experience for all gamers, offering balanced mid-tones and bass ideal for FPS shooting games, as well as daily activities like listening to music and watching movies. Its leatherette headband and ear cushions with high-density foam ensure ultimate comfort during extended use. The headset is also compatible with MasterPlus+ software, allowing you to create a custom soundscape tailored to your precise audio preferences
The Sound Quality You Want and Need
7.1 Virtual Surround Sound
We’ve put just as much thought into the internals as the design. The CH331 is equipped with custom-tuned 50mm drivers in each earcup, delivering a crisp, detailed soundstage. And for those looking to take it to the next level, virtual 7.1 surround sound provides true, immersive audio experience.
Keep it Inline for Convenience
Immediate audio control
No more wasting hotkeys on sound controls, or getting out of your groove to hit up the settings menu. Convenient controls right on the cable allow you to adjust volume, mic, and other settings without pausing the action.
ALL-AROUND CLARITY
The CH331 features an omnidirectional boom mic, delivering a highly sensitive microphone that captures your voice with clarity, ensuring your teammates hear you loud and clear during intense combat moments. Plus, it's easily removable for on-the-go convenience
LIGHT IT UP
The illuminated, minimalistic logo adds an ambient glow to your gaming experience, enhancing the signature Cooler Master aesthetic profile.
INSTANT PLUG-AND-PLAY
Get in the game faster with no need to fiddle with any settings. The CH331 ensures you spend less time configuring and more time enjoying the action-packed gameplay right out of the box.
  • Product Number CH-331
  • Headphone Driver Diameter 50mm
  • Headphone Frequency Response 20-20,000Hz
  • Headphone Impedance 16Ω
  • Headphone Sensitivity (@1kHz) 103 dB ± 3 dB
  • Headphone Input Maximum 30mW
  • Headphone Cable Length Approx. 2.2m
  • Headphone Connector USB Type A
  • Headphone Headband Material Steel and plastic headband, PU leather and foam cushion
  • Headphone Ear Cushion Material PU Leather
  • Headphone Supply Voltage USB 5V ± 0.25V
  • Microphone Pick-up Pattern Omni-Directional
  • Microphone Frequency Response 100 - 8,000 Hz
  • Microphone Sensitivity (@1kHz) -40 dB ± 3 dB
  • Microphone Signal to Noise Ratio 58 dB
  • Microphone Type Detachable Flexible Microphone
  • Physical Dimensions (L x W x H) 179.4 * 96.3 * 210.1 mm / 7.06 * 3.70 * 8.27 inches
  • Physical Weight 371.2g / 0.82 lbs (Including Cable)
  • Physical Weight 294g / 0.65 lbs (without Cable)
  • Product Audio
