ATX Dual 24 Pin 90 Degree Adapter Bridge image number 0
ATX Dual 24 Pin 90 Degree Adapter Bridge image number 1
The ATX 24 Pin 90 Degree Adapter is a great option for changing the way you connect your ATX 24 pin main power cable to your motherboard. It opens up a host of new options for routing your main power cable from behind your motherboard tray. It also helps improve the appearance of your system. That's why the product's slogan is "build from a different angle". But 90 degrees is only one new angle. It offers plenty of additional options for PC builders, but for some 90 degrees is still not enough.
