Cooler Master Launches V-Series CPU Air Coolers Featuring Patented 3DHP Technology
Advanced Cooling Meets Automotive-Inspired Design for Unmatched Performance and Style
Summary
TAIPEI, Taiwan January 7, 2025 — Cooler Master, a global leader in PC components and tech lifestyle solutions, today announced its latest innovation: the V-Series CPU Air Coolers, featuring proprietary 3D Heat Pipe (3DHP) technology. Combining cutting-edge cooling performance with a bold, automotive-inspired design, the V-Series redefines expectations for air cooling solutions. easily keep up with their performance needs while enjoying a sleek, minimalistic look.
The V-Series, inspired by the iconic V-engine, includes four models—V4, V6, V8, and V10. Designed for superior thermal performance and aesthetic appeal, the series leverages Cooler Master’s patented 3DHP technology. By incorporating a central heat pipe directly above the CPU’s heat spot, this innovation delivers exceptional heat dissipation while using fewer heat pipes than competitors, ensuring maximum efficiency and performance.
“Cooler Master’s V-Series CPU air coolers represent the next step in thermal technology,” said Jimmy Sha, Cooler Master CEO. “With our patented 3DHP technology and unique design, we’re not just keeping CPUs cool—we’re setting a new standard for what cooling solutions can achieve. This series exemplifies our commitment to engineering excellence and empowering users to build systems that look as good as they perform.”
Features
• Patented 3D Heat Pipe (3DHP) Technology: Enhanced heat dissipation with a central heat pipe directly above the CPU’s heat spot for superior thermal performance.
• Bold V-Engine-Inspired Design: Automotive-inspired aesthetics bring style and power to your PC build.
• Dual 120 mm Fans: Optimized for superior airflow and efficient cooling.
• ARGB Lighting: Customizable to match any PC setup.
• Ready for Your Build: Compatible with the latest Intel and AMD processors and includes Cryofuze Thermal Paste for superior heat transfer.
Upgrades in V8 & V10 Models:
Dual-Tower Design: Expanded cooling capacity for intensive workloads.
Dual Ball Bearings: Reduced friction and noise for extended fan life and quieter operation.
Higher Thermal Dissipation: Rated for up to 340W TDP, ideal for overclocking and extreme performance.
Proprietary 3D Heat Pipe (3DHP) Technology
Cooler Master’s patented 3DHP technology advances traditional heat pipe designs by placing an additional heat pipe directly above the CPU’s heat spot. This significantly enhances heat transfer and distribution, ensuring peak CPU performance under heavy workloads.
The V-Series CPU Air Coolers will be available in March. For more information, please visit Cooler Master’s Website.
About Cooler Master
